Old 11-18-2008, 03:25 AM   #1
pinoypizzaboy
Drives: 08 toyota yaris LB
im a noob but 20+ whp is a big change for the yaris ecu wont this require some management of some sort? this is almost the same gains as the blitz
pinoypizzaboy is offline   Reply With Quote
Old 11-18-2008, 12:11 PM   #2
richardholdener
Drives: 2008 Yaris hatch
Since this is a mass air management system, it has been very self compensating in terms of air/fuel and timing (we monitored via palm pilot), so no changes to ECU are necessary. Air fuel curve was basically same as stock. We think additional timing may help power since we were only registering a peak of 20-21 degrees (less in the mid range).
richardholdener is offline   Reply With Quote
Old 12-13-2008, 04:24 PM   #3
4MPG
Drives: black 5spd hatch yaris
Pretty impressive.. dammed near 25 percent increase in power with zero tuning and only boltons.
Is there no way to tune the car other than a complete standalone system? I can defiantly see where your loosing some power to the tune (especially the dips between 4200~ and 5500~).
I have seen (on this forum) where people did piston swaps from other Toyota cars to get a bump in compression, any plans to try this out on your test mule?
4MPG is offline   Reply With Quote
Old 12-13-2008, 05:49 PM   #4
richardholdener
I am very curious to know how you see where we are losing power due to tuning based on the graph provided. Since there is no evidence of the air/fuel ratio or timing values, how do you know where tuning may improve the power? To answer your question about tuning, we will be employing an FIC on the yaris motor (basically to increase the timing-since air/fuel is near spot on already. No plans on changing compression-the test motor belongs to another forum member and we don't think he will like us tearing his motor apart. BTW-The dips in the curves you are refering to are a function of the resonance waves from the long-tube headers and intake manifold.
Old 12-13-2008, 06:07 PM   #5
4MPG
Your seeing these kinds of dips etc due to the headers? The dyno sheets of the before/after of the headers really show some spots (4-5200) where it looked like a tuning issue, as it was present but not as exaggerated on the stock dyno, which I figured was a tuning issue. Its probably alot less important than it looks... on this scale every small change looks like a monster.
Old 12-13-2008, 07:58 PM   #6
its not really a dip in the dyno, its just a flatter tq curve vs stock.....
Old 12-13-2008, 09:13 PM   #7
richardholdener
My point is that the only way to determine if any dips in the power curve (HP or TQ) are caused by "tuning issues" is to compare the dips versus the air/fuel curve or the timing curve. This way you can determine if the dip is caused by a lean or rich mixture or by excessive or insufficient timing. Simply looking at dips in the power curve will not allow to to determine the reason they exist. As indicated previously, the dips in the power curve are caused by resonace tuning offered by the new induction and exhaust, not by air/fuel or timing. We know this because both air/fuel and timing curves remained identical before and after the header and/or intake installation (we always monitor both while dyno testing). This should clear everything up.
Stock Wheel Covers barryware Willing to Buy by private party 5 11-04-2008 01:22 PM
Stock Wheel Covers? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 11-04-2008 10:03 AM
stock wheel wushumasterku Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-23-2007 11:52 PM
