#1 | |
first, it's only for transmissions with the stick ON the trans (RWD setups) second all they show you is pretty pictures of the paddles. here's my work so far my initial design will be for MT only. here's my chicken scratches from last night.. ![]() and my truth table.. gotta integrate this into the programming now.. my brain hurts ![]() i1-i4 are cylinder position feedback inputs (so the PLC knows what gear you're in) i5 is "upshift" input from the paddles i6 is "downshift" input from the paddles Q1-Q4 are outputs for the valves that will control the cylinders |
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
![]() great work! |
#3 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Their Street Manual All Products page shows good images of the actual modules that bolt in place of the stock shifter assembly to control the existing cable-drive stuff. *ALL* their systems are designed to work with cable-driven transmissions actually.
#4 | ||
either way, the intent of my setup is to do away with cables ;) |
#5 | |
The MasterShift kit comes with a programming cable and software CD for a reason: It's for setting the distances the box actually has to shift the cable-linkages for the gate-selector and syncro-selector inputs, and specifying paths and routes for the shifting to follow. And any cable linkage can be replaced with a hydraulic linkage, witness modern brakes versus the old cable-powered brakes used as recently at the 80's. Hell, many vehicles with in-board brakes (brakes mounted beside the differential, bolted to the chassis instead of part of the wheel assembly, Jaguar's and Hummer-1's mostly) can have hard brake line going all the way to the brake calipers. They'd use hydraulics more places, but it's a lot more expensive to design and prone to maintenance headaches than a length of steel rope inside a plastic sheath, which is almost all a transmission-cable is since it doesn't have to deal with large forces like brakes do/did. Didn't mean to come off as knockin' on the work you're doing, it's looking awesome so far. :-)
#6 | |
i'm jealous of their paddle controls :( |
#7 | |
If nothing else, if you could figure out how to be electrically compatable with their paddle-shifter sets it'd make it one less part to deal with being the only source of yourself if/when you sell these later.
#8 | |
that's my price range lolcalled them... their website is shit.. that's $70 for a PADDLESHIFT UPGRADE.. sold separately they want $375. stay tuned for something made by me for $70 lmfao Last edited by Tamago; 11-26-2008 at 11:50 AM. |
| Didn't buy; awkward shifting? | drmitch | New YARIS Purchase Forum | 89 | 03-03-2009 09:44 AM |
| Yaris Auto Transmission shifting | g man | Canada | 9 | 08-23-2007 12:16 PM |
| Shifting (A/T) | daq421 | General Yaris / Vitz Discussion | 54 | 04-03-2007 12:30 PM |
| Paddle Shifter? | spkrman | Performance Modifications | 10 | 03-09-2007 05:17 PM |
| Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
