Old 11-18-2008, 11:01 AM   #1
eric81
eric81's Avatar
Drives: Toyota Salesman
The Silky Smooth is far too smart to be from earth. We have aliens. Anyone got any Raid? Anyone? And what exactly does that mean anyways? The Silky Smooth... what is so silky smooth? I don't understand?
Still, crossthreaded A?F sensors suck, and they keep us from being able to use our aftermarket parts without replacing a bunch of other stuff. I also recommend checking the little silver bolts on the top of your engine that hold the spark plugs in place (they are black, have one bolt in them, and there are four of them across the top of the engine) to see if their bolts are as bad as mine were. They used a cheap bolt on mine and I snapped it in half trying to put it back in place. I took a different one out to measure it at the hardware store, and it was all stretched and warped too. So I replaced them all, and they were all bad. Toyota sure did save those pennies when it came to our cars.
eric81 is offline   Reply With Quote
Old 11-21-2008, 12:35 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
This is typical Asian practice, see it a lot on street bikes - its called "torque to Yield" the bolt is not reusable and permanently strained out of shape. It keeps the fasteners from coming loose. Unlike GM whom has all kind of problems with "oversized" bolts coming loose on intake manifolds because they are under-torqued and back off over time. SAves on washers also which are a bitch to handle in assembly lines.
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Need LA Yaris liftback Owners for Yaris Commercial weinsteins General Yaris / Vitz Discussion 10 05-04-2006 04:42 PM
