Old 11-19-2008, 01:16 PM   #1
bump anyone here has shots of the yaris car pager stock..connections and wire harness..??
Are you talking about the OEM keyless entry flashing the lights when you lock/unlock the doors?
Old 11-19-2008, 01:36 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
yes sir.. it flashed all lights when i press page and i need to cut the wire for the park light..i dont want the small park light flashing while im paging the car..
Old 11-19-2008, 02:17 PM   #3
OK. For the OEM keyless system the ECU controls the light flashing:
(b) Answer-back function:
• The main body ECU receives the door unlock detection switch's ON / OFF signals and uses these signals to confirm if the door control operation has been completed. The main body ECU then outputs the hazard warning light control signals to flash the hazard warning lights as an answer-back indication.
It is considered to be a "customizable parameter", which can be changed by the dealer:
5. WIRELESS DOOR LOCK CONTROL SYSTEM
Main Body (Main Body ECU)
Display (Item) Default Contents Setting
Hazard Answer Back ON When wireless lock switch on transmitter pressed, illuminates all hazard warning lights once. When unlock switch pressed, all hazard warning lights illuminate twice ON / OFF
Wireless Control ON ON /OFF of wireless door lock function ON / OFF
Panic Function ON Operates security alarm when panic switch on transmitter continuously pressed for 1 second ON / OFF
Unlock / 2 Operation ON Function that unlocks driver side door when unlock switch on transmitter is pressed once, and unlocks all doors when pressed twice. if setting is OFF, pressing unlock switch once makes all doors unlock. ON / OFF
Auto Lock Time 30 seconds Time until relocking after unlocking with wireless door lock function 60 seconds / 30 secondss
FS: AFE drop-in filter and Stock Airbox with Cutouts FunctionSpec Items for Sale by private party 16 06-02-2010 01:36 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 04:56 PM
Stock 6 disc MP3 deck + speakers for sale!!! chino_potato Items for Sale by private party 16 02-05-2009 07:27 PM
noob question about stock tires xCookiE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-19-2007 08:40 AM
question about stock stereo wiring? punch In Car Entertainment + Electronics (audio / video / alarm) 3 07-19-2006 03:22 PM
