Old 11-23-2008, 12:37 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
I cut roughly half of the accumulation on and half of the misting behind my LB simply by adding on the OEM mud flaps. That means that much of the turbulence comes from underneath the car.
- Brian
Share the Road
Old 11-23-2008, 05:13 PM   #2
GeneW
Drives: 2008 Yaris
Are you being ironic, Brian? :)
Could also mean that most of the crap comes from the rear wheels, which when you vent it downwards doesn't contaminate the rear glass.
Gene
Old 11-25-2008, 11:56 AM   #3
BailOut
BailOut's Avatar
Gene
No, there is no irony there. I did not expect that kind of result from adding the mud flaps but I got it.
- Brian
Share the Road
Old 11-28-2008, 09:22 PM   #4
metalshark
MetalShark
Drives: 2008 Yaris LB
Under Car Turbulence
Way back 40 years ago several road racer types cut their times a lot by smoothing under car air flow. Its such a good trick that NASCAR requires you to use stock floor pans when you build a car. Some racers modified floor pans to create large down forces at speed. Great in the turns......unless you suddenly loose that suction for some reason.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
