Old 11-25-2008, 12:04 PM   #1
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
which of these is a cable shift manual transmission?
either way, the intent of my setup is to do away with cables ;)
They're specifying that they support some of the transmissions that a lot of 'universal sequential shifter kits' don't, because the stock transmission is a rod-linked assembly or true top-mount shifter. Those are the transmissions that they specifically have adapter modules designed and tested for to link to their cable-shifter two-servos-in-a-box brain, and pre-programmed settings for said brain-in-a-box. And said vehicles are expensive enough to justify a $1900-$2400 paddle-shifter kit. :-)
The MasterShift kit comes with a programming cable and software CD for a reason: It's for setting the distances the box actually has to shift the cable-linkages for the gate-selector and syncro-selector inputs, and specifying paths and routes for the shifting to follow.
And any cable linkage can be replaced with a hydraulic linkage, witness modern brakes versus the old cable-powered brakes used as recently at the 80's. Hell, many vehicles with in-board brakes (brakes mounted beside the differential, bolted to the chassis instead of part of the wheel assembly, Jaguar's and Hummer-1's mostly) can have hard brake line going all the way to the brake calipers.
They'd use hydraulics more places, but it's a lot more expensive to design and prone to maintenance headaches than a length of steel rope inside a plastic sheath, which is almost all a transmission-cable is since it doesn't have to deal with large forces like brakes do/did.
Didn't mean to come off as knockin' on the work you're doing, it's looking awesome so far. :-)
WolfWings is offline   Reply With Quote
Old 11-25-2008, 12:36 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
yeah i'd only poked around their site slightly til now. they do seem to cover their bases but like i said my real issue is the actual cables being in the way of the downpipe so doing away with them and replacing with DOT airbrake line i can mount well away from the heat is the idea here..
i'm jealous of their paddle controls :(
Old 11-26-2008, 03:15 AM   #3
WolfWings
WolfWings's Avatar
They do offer the paddle shifter sets by themselves on their store page. Including the wireless ones that you just strap to the steering wheel, though you do have to change the batteries in those periodically. I'd go for that approach myself, since I have a leather sewn-on steering wheel cover I can just re-sew over the binding straps to hide them on the wireless units.
If nothing else, if you could figure out how to be electrically compatable with their paddle-shifter sets it'd make it one less part to deal with being the only source of yourself if/when you sell these later.
Old 11-26-2008, 09:22 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
if i read that right, the basic paddle setup is $70? that's my price range lol
called them... their website is shit.. that's $70 for a PADDLESHIFT UPGRADE.. sold separately they want $375.
stay tuned for something made by me for $70 lmfao
Didn't buy; awkward shifting? drmitch New YARIS Purchase Forum 89 03-03-2009 09:44 AM
Yaris Auto Transmission shifting g man Canada 9 08-23-2007 12:16 PM
Shifting (A/T) daq421 General Yaris / Vitz Discussion 54 04-03-2007 12:30 PM
Paddle Shifter? spkrman Performance Modifications 10 03-09-2007 05:17 PM
Sticky When Shifting and Sticky When Reving? jouslee DIY / Maintenance / Service 22 01-23-2007 11:07 PM
