Old 11-25-2008, 06:38 PM   #1
MadMax
MadMax's Avatar
Thanks for the suggestion, but I was hoping to be able to wire it as (I believe) it was intended. Plus, I am concerned over cutting wires (I'll admit it, I'm a chickenshit when it comes to my new car).
I'm curious, can I at least test the connection by sticking a bare wire into the location in the fuse box?
Cheers! M2
Old 11-25-2008, 08:40 PM   #2
Cheers! M2
You can hold it against the terminal to do a quick test.
You actually don't have to cut the wire to tap into the column circuit - You can use one of the tap splice connectors like this (available a most autoparts stores):
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 3 10-20-2008 06:36 AM
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 11:48 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-03-2006 12:38 AM
