Old 11-25-2008, 10:39 PM   #1
Dave
Drives: 2007 Yaris Sedan
I seem to get a rattle from the fan when the engine is cool (after the "cool engine" light has gone off, for about the first 15 minutes of driving) and at an idle, while the fan (any setting) is on max heat and at speed 2 or greater. Any suggestions?
It goes away when the engine warms up, doesn't rattle while I'm driving, and is definitely coming from the front/dash area.
Dave is offline   Reply With Quote
Old 11-25-2008, 10:54 PM   #2
It might be the "Upper Instrument Panel Rattle" issue (see the TSB in this post):
http://www.yarisworld.com/forums/sho...&highlight=tsb
I forgot that there is also a TSB on the "Blower Motor Noise & Vibration" where the resolution is the installation of plastic mesh between the glove box and the fan assembly.
air circulation fan problem tomdf DIY / Maintenance / Service 8 12-10-2012 06:53 AM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
constant radiator fan coming on? adeel DIY / Maintenance / Service 0 04-12-2007 07:19 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
Question: Yaris' Radiator Fan: Electrical or Clutch-type? TRD_Yaris General Yaris / Vitz Discussion 5 06-11-2006 09:07 PM
