Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Why not just install one yourself?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() Drives: 2008 Yaris Join Date: Nov 2008
That does not really fix the issue of the odor. A wet cabin filter cannot be the culprit when there isn't one installed. I already removed the glove compartment and removed the carpet on the passenger side just to see if there is any leak from the drain or any hoses and I can not find any. I already sprayed lysol (as suggested) on the vents but the odor is still there.
Plus it defeats the purpose of installing a cabin filter if I drive with the windows open just so I don't have to use the AC and increase fuel economy back when gasoline was $4+/gallon. In any case, any other suggestions where the smell can be coming from. I sure hate to bring the car to the dealership as I know they would just tell me "we're not smelling anything". Any help would be much appreciated. |
#3 | |
Did you actually clear the condensate drain tube? |
Yes I did that yesterday, I used a long thick plastic cable tie and inserted it in the drain tube and the drain seemed clean and clear. Just for good measure, I tested the cable tie I used for similar odor and there was non't any odor. Morever, it was also dry (that's because I have not used the AC that day because of the cooler weather) which meant that there isn't a stagnant water condensate in the tube. Oh yeah, I installed a cabin filter while I was at it ('should have gone back to the dealership and told them they sold me the car without the cabin filter installed).
This is really bugging me. I googled the issue and to my surprise it is not an uncommon problems with cars of any type. I may have to go to the dealership and deal with the inconvenience. *sigh. Why are dealership customer service only good when you're buying the car but it's the exact opposite when you're having your car fixed under warranty (at least from my experience)? |
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 12:59 PM |
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
| $7 Ram air intake pictorial | turbodiesel | Performance Modifications | 19 | 10-27-2008 05:46 PM |
| air filter multipart | btc50 | DIY / Maintenance / Service | 1 | 08-31-2007 06:37 PM |
