![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
I found the high silicon numbers on so many of the samples to be a bit disturbing, especially the numbers >200. I've run 11,000+ miles on a motorcycle oil change and had numbers less than 10. My understanding is that high silicon numbers indicate bad air filtration.
But after re-sorting by vehicle mileage, it became apparent that most of the high silicon number vehicles had very low mileage. In this case, I'd guess that the high silicon count comes from break-in contamination. It looks like this illustrates a very good reason to change the oil very early. I wouldn't think 100 miles would be too soon. Also notable was that the three samples using the bypass filters were not showing the great numbers that you might expect, and the silicon count was high. I think they need to change the oil more often... Last edited by Reddog99; 11-26-2008 at 02:30 PM. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-24-2009 12:30 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 05:27 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 04:25 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
