![]() ![]() Drives: 2009 Yaris Sedan (Black) Join Date: Nov 2008
yes that makes sense, thanks. and also, you're right...even after 35,000 miles, you will only be 35 miles off....so say you drive 105,000 miles (close to the end of the life of the car), you'll only be 105 miles off on the odometer...still not that big of a deal. thanks for the clarification castrex!
this brings up one other question...you said that fuel economy will suffer if i get the 17" rims. how much will it suffer, and why? i currently avg around 37mpg. on 17s, will it go down to like the low 30's? |
#2 | |
Who said Yaris was slow?
The reason is basically the weight... The weight of the wheels is not simple dead weight. Is spun weight. A wheel is a rotating mass... So that weight has a big impact on the acceleration. If you have a very heavy 17 wheel your engine will have to use more energy to make them rotate. As simple as that. Another reason is that usually 17 wheels will use wider tires. 205 or 215 wide. That also means more drag. A larger contact area means more friction. Is all a compromise! |
#3 | |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
^^ What he said. Also even if you go with 15" wheel, there are some heavy one and light one as well. Don't get blinded by just the size of the wheel itself. I found this site quite useful of finding out the weight of the wheel and the weight of your tire as well. Go to any wheel or tire you desired and hit on the spec button. www.tirerack.com
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
| 18in rims | keshaw.sharma | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 11-02-2008 01:15 AM |
| FS Brand New Stock rims w/ Tires | FlintS | Items for Sale by private party | 10 | 09-24-2007 08:22 PM |
| Need help when ordering my tires and rims | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-26-2007 09:40 PM |
| FS: 07 yaris RS stock rims n tires | thegame11 | Items for Sale by private party | 5 | 04-15-2007 01:25 PM |
| hufeisen rims | JustYYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-17-2007 03:16 PM |
