#19 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
One change I would make -
Make sure you break the oil filter loose BEFORE you drain the oil. You don't have to pull it off, just make sure you can turn it. That way if you have a problem getting it loose you can go get a proper tool and not be stranded. |
#20 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
A few things I would change....
1) Engine and oil should be HOT to change the oil...don't let the car sit for an hour 2) Open the filler cap after you open the drain plug 3) Use wheel bearing grease to lube the filter gasket and spin on hand tight 4) I think that you let the car down before putting the drain plug back in. That's an important step.
#21 |
![]() ![]() ![]() Drives: Silver Hatchback Join Date: Jul 2006
I disagree with the above, it doesn't need to be hot but not cold. Warm enough to run out smoothly not hot enough to melt gloves to your hand(running temp). Filler cap doesn't matter when opened, aslong as you open it. I would never use anything on a seal that would touch my engine oil unless it is the same oil(old or new) Granted its not much grease, but its an undesired product that may or may not contaminate my oil. Don't have to be down to put the drain plug it just gotta be down before you start the car and check the levels. Aweful hard to get under a Yaris to put the plug back in when its not on stands. I've always use old oil, 1 because unless I see metal flakes or grittyness I feel that it is safe to use 2 my finger doesn't reach far enough into the new oil to get some.
O I'm envious of that stove, I want it. It looks like either a Viking or Wolfe. |
#22 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
![]() ![]() Ohhhh, nasty but funny as hell!On a serious note, wait for the oil to settle down (give it at least 10-15 minutes) after a drive and check your oil level carefully. Too much oil will cause your crankshaft to splash on the oil inside the crankcase and ..... create too much bubbles (like milk shake, eh) and consequently your engine lubrication will be compromised.
Benggolf2 |
#23 |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
It's tight, however I am able to do the oill change without using jacks. I keep cat litter handy. There could be a spill.
Making a decision without following it with an action is still a fantasy. |
#24 | |
You want the oil as hot as possible for maximum flow for the longest period. Opening the filler cap after the plug is pulled keeps the oil from shooting out all over your hands so you don't have to worry about a burn (basic physics). A small amt of wheel bearing grease on the gasket in not going to contaminate your oil....it more effectively seals the flange and allows you to remove the filter with ease at the next change (by hand). It doesn't even come in contact with the oil. |
#25 | |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
never thought of that, I will def try it next time out. thanks
#26 |
how many people are going to give the exact same advice lol...
#27 |
#28 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
That was a fun thread.........we have a guy here that wears a Parrot suit when changing his oil.
#29 |
Beast
Besides the attacks, Great DIY, Wish i used this one when i last changed my oil =D. Just get some pro shots and edit them on mspaint next time and it will be cooler -thumbs up-
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#30 |
I don't think anybody was trying to give the guy a hard time as much as it was, we were/are concerned that he may be putting too much oil into the crankcase which is not a good thing EVER. Aside from that...we are all just having a little bit of fun with it...I mean, the guy did dress up as a banana. Let's all just lighten up a bit....
#31 |
I've never heard of Valuecraft filters, are they any good?
Also, you state to rub the oil on the filter's THREADS not the gasket..... ![]() Great pics made it a fun and intersting DIY.
#32 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
not trying to be rude , just don't want to see yeh have any damage done by overfilling . Imagine TOYOTA would void your warranty if something should occur . Its a trial and error for all . Keep up the humor , this world could use more of it
#33 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Cool. I cant wait to get to work on Monday and check it! I can't see pic yet since I'm on dial up right now. Man, we all got to really carefully read the owners manual on the OC. and everything else. That oil level is critical to be at the line or less - maybe no more than 125ML over fill . Running with overfilled oil will void the warranty if you have engine failure with the overfill. I think there is a BIG warning in the manual about that. In the Motor, That crank and pistons are spinning like an airplane propeller at full power in the crankcase, and if oil is up around it will pick the fluid mass up and spin it like a tornado - possibly moving it away from the pump pick up, And you're loosing big time power and torque. But a lot of people said this already. Now lets have fun profilin in the yAR. ( I dont have a yar my sis has it but I take it every once in a while;) Its No Fiat, but it would be good maybe with hard strut bushings and lower arm bushing and a bit firmer springing)
#34 |
here's a car ramp D.I.Y. ( pics ) for 1st generation SCION XB ( boxy YARIS ) . Go to http://s49.photobucket.com/albums/f2...t=IMG_1243.jpg , could use 1 level for ramp instead ( plenty clearance with only 1 board ) . Then put 1 strip of wood across each end ( stoppers ) to prevent driving of ramp . Should take less than 1/2 an hour to make ( cut and nail ) .
#35 |
SIPNDEW
valucraft oil filters are sold at autozone and are made by the same people as stp and about 4 other brands.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| DIY - oil change | kurokoma-kun | DIY / Maintenance / Service | 7 | 11-20-2008 12:12 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 08:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
