Old 11-27-2008, 03:59 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
So long as it is tight and it ain't wiggling, it's all good! Right?
marlondog is offline   Reply With Quote
Old 11-27-2008, 04:43 PM   #2
jkuchta
Drives: 2007 Yaris hatch (red)
Well...yes and no. If its pretty close to the correct torque, you should be fine. If it's too loose or too tight, then the bolts could brake. Too much torque will cause the bolt to yield too muchwhich will cause the bolt to stretch and loosen, and too little torque could cause just enough wiggle room for vibrations or sudden loads to shear the bolt head off.
My vote is to invest in a good torque wrench (remember, you get what you pay for) and torque every bolt you install or loosen on the car to spec. It may be a little anal, but it's worth it.
jkuchta is offline   Reply With Quote
Factory armrest install DIY. PetersRedYaris DIY / Maintenance / Service 16 07-27-2012 05:25 AM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 09:41 PM
WTB Factory 15'' Alloys or 15'' Steelies W/ tires tealio Items for Sale by private party 5 04-25-2007 06:34 PM
looking for factory 15's or factory tires tealio Southwest 7 04-15-2007 01:51 PM
