Old 11-28-2008, 01:17 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
DFA,
I would advise against Systems Engineering as a starting point. And this advice is coming from a Systems Engineer.
I suggest that you pick a field of engineering where you think you will enjoy the work. Then, during your career, you should expand your work into areas that are not your primary strengths. As you move from one discipline to the other, you will find out that you have acquired the knowledge about the entire product line that your industry produces.
By expanding your horizon beyond your specialty, you will have grown into a Systems Engineer. Example, I started in Electronics, moved to Integration & Test, next to Software, then without knowing it... was labelled a Systems Engineer.
I may be biased....but with 24 years of career growth, I firmly believe that Systems Engineering is where it's at. It's high profile, high stress, but comes with high rewards.
Good-luck.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
Dumb Question sambo42xa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-16-2007 10:51 AM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 11:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
