Old 11-29-2008, 06:07 AM   #1
Noisetube
Drives: Vitz RS...
I'm pretty sure I've seen that engine it on a 2003 1.3L Daihatsu Sirion/Daihatsu Storia/Toyota Duet (yeah, it never made it to the US)
I think that engine is the one eTiMaGo mentioned, the 2SZ-FE... and per Wiki, the Sirion actually uses the K3-VE (another 1.3L but the one I've seen looks more like the 2SZ-FE)
Anyway, here's a drop in http://www.blitz-uk.co.uk/ProductItem-2430.aspx for the "New Yaris 1.3, SCP90, 2SZ-FE, 08/05>"
And here's another: http://www.zenaracing.com/shop/produ...ts_id=10002491
Send a private to Katana to check where he got that one (I bet it comes from the 1.0L)
BTW, look at what I bumped into:
"Another difference is that the Avanza is only supplied - in the Philippine market at least - with a gasoline engine, a 1.3 liter K3-VE and a 1.5 liter 3SZ-VE, with the latter enjoying Toyota’s Variable Valve Timing with intelligence (VVT-i)technology. Dream Wonderland also notes that the 3SZ-VE is different from the 1.5 1NZ-FE engine that powers the Toyota Vios, in that the former has a cast-iron block while the latter’s is made out of aluminum"
Interesting... and it looks like the 3SZ-VE is used in a gazillion diferent Toyota cars, including the second gen JDM bB (the first gen used to run on the 1NZ)
''If improved evolutionary fitness guarantees the survival of the species, as proposed by Darwin's theory of natural selection, then the Blitz bB will certainly be regarded as the champion of its kind. Undeveloped, the second generation bB comes equipped with either a 1.5 liter (109 hp) or a 1.3 liter (92 hp) 16-valve VVT-i four-cylinder engine, not nearly enough to impress the sophisticated urban female. Thanks to the genetic engineers at Blitz, this offspring received some desirable traits that make this specimen different from the others.
Beneath its sinister exterior is an even more menacing supercharged four-cylinder engine, which greatly improves the displacement to output efficiency by converting kinetic energy from engine rotation into thermal energy released during combustion. Simply put, some of the engine's power is converted to create a more powerful internal explosion, which, through the pistons and connecting rods, causes the crankshaft to turn more forcefully.
Toyota provided the engineers at Blitz with a solid platform for producing more power. This 2006 bB came equipped with the 1.5L, 3SZ-VE engine, a relatively new engine family produced by Daihatsu of all companies, which offers a cast-iron block in lieu of the Scion xB's aluminum block. Although heavier, the cast-iron block is better suited for forced induction since the volumetric increase following combustion is less likely to have damaging effects on the stronger cylinder walls. "
Turbo... Powered by TRD
Noisetube is offline   Reply With Quote
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
intake question and suggestions Adriaan Performance Modifications 2 01-31-2007 04:54 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
