Old 11-30-2008, 08:20 AM   #1
CB900F2
Drives: 08 Sedan
Yes..
My 08 Sedan with the power package has the tach in the dash..
DAM!... I thought I had all the planets aligned up!... (Wiring, ECU, Part#s for the OEM CC parts)..... I would have thought (assumed!), that Toyota would have used the same dash for both cars that have the OEM CC installed or not (with the tach of course)… DAM!...
Anyone outside of N.A that has a 08 Sedan with the tach, but no OEM CC installed, can you take a picture of your dash too see if you have the CC indicator in your dash?... It is preferred if you have a metric dash (KM)
DAM, DOUBLE DAM!!!
P.S.. Can someone with a 08 US Sedan (w/tach) take the same picture… I would like to see how well does the CC indicator shows up.
Originally Posted by Revsson View Post
Does your Canadian Yaris come with a tachometer?
Looking at the 2007 Factory Service Manual, it shows the cruise light
in a different spot on the I/P if you don't have the tachometer.
Take a look at page 15 of the Cruise Control pdf:
http://www.etimago.com/yaris/repairm...%20Control.pdf
That being said, I have a 2009 LB with Power Pkg and CC, but no tach.
My indicator is in the upper right, like the pdf shows for the tach model.
Maybe the 2009 service manual would show something different.
Old 11-30-2008, 10:45 AM   #2
Originally Posted by CB900F2 View Post
Yes..
DAM, DOUBLE DAM!!!
Wow, looking at the EPC, there are quite a few iterations (12+) of the 08 sedan combo meter:
None mention cruise, but the following have tach:
83800-52W10
83800-52F21
83800-52S60
83800-52S70
83800-52S40
83800-52S50
83800-52E81
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
