Old 11-30-2008, 04:51 PM   #1
500snakz
500snakz's Avatar
Drives: 08 Polar white hatch
NO...it's NOT a piece of paper stuck in the fan. I pulled the glovebox and filter before I posted this. With the glovebox pulled out, and the filter removed, I can look into the opening and see the fan assembly and it makes a ticking noise coming from the fan blower motor.
I was just wondering if anyone else had a problem with theirs?
Thanks CTScott, I will follow up on that tsb...
500snakz is offline   Reply With Quote
Old 11-30-2008, 06:05 PM   #2
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
You under warranty? Call the service department and bitch up a storm. Now a word of warning...... if it is something that got sucked in and is hitting you will end up paying for the repair. In a longshot the fan may be bad..... parts do go bad and warranty should cover it.
air circulation fan problem tomdf DIY / Maintenance / Service 8 12-10-2012 06:53 AM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
constant radiator fan coming on? adeel DIY / Maintenance / Service 0 04-12-2007 07:19 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
Question: Yaris' Radiator Fan: Electrical or Clutch-type? TRD_Yaris General Yaris / Vitz Discussion 5 06-11-2006 09:07 PM
