Old 12-02-2008, 06:03 AM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
if you do that way it will lock you out the correct way to do it since i own a d3 was to pull the mute wire outta the harness along with the metal tab and move it to the pin above and ground that wire and the parking brake wire. you cant use the old toggle switch trick cause as soon as it senses movement it will lock the menu out or shut the screen down theres an actually thing on avic411.com to do the bypass for all the avics they come out with
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
