Old 12-02-2008, 09:14 PM   #1
doesn't disabling the ABS make the car behave exactly like the rest of us that don't have ABS to begin with? I like the control I have with my car without ABS.
Old 12-02-2008, 11:05 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Theoretically, yes but the brake balance/assist could be defferent between the ABS and non ABS cars. I have no idea, that is just speculation.
Most non ABS cars have a fairly linear pedal feel while ABS cars are more progressive. Toyota may have just left it alone and thrown in an ABS box.
Old 12-03-2008, 09:01 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
if your ABS is anything like mine, your car will NOT handle like a non-ABS yaris.. on R comps i gently tapped the brake heading into a slalom and all 4 wheels locked up instantly. the brakes are over-boosted without the ABS pump running.
Old 12-04-2008, 02:17 PM   #4
ppk
Drives: 2007 liftback
Stock brakes I assume... Then that is a good reason to not do it. I'll leave it as it is, tighten the e-brake and raise the pressure in the rear tyres to get it sliding a little more. Which brings me to another question - how do you remove the plastic trim around the e-brake to get to the nut that tightens it? I fiddled around with it and removed the little plastic square right in front of it (the thing with the lock/unlock switch if you have electric door locks) and the rubbery part that covers the base of the e-brake. I can see the nut but the main plastic part in between the too seats is preventing me from reaching it. I looked around but don't see any nuts to remove it... Is it just clipped in? I don't want to break anything.
ppk is offline   Reply With Quote
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 07:11 PM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 09:12 AM
ABS Virgin!!! yaris-intuit General Yaris / Vitz Discussion 23 11-29-2006 12:49 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
No ABS on Sedan?? hans_fh General Yaris / Vitz Discussion 2 10-12-2006 03:39 PM
