#37 |
Cmon people I want to see these headers fabricated
#38 |
![]() ![]() ![]() Drives: 2008 Yaris hatch Join Date: Oct 2008
#39 |
What material will the parts be made from? Also, will the cat be a bolt on affair (i.e. replaceable)?
#40 |
#41 |
#42 |
I am VERY interested in a stainless version.
#43 |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Okay, after doing some research I'm fine with the Jet Hot coated mild steel version if stainless turns out to be prohibitive.
And are the cat/resonator options all on the midpipe?
#44 |
I'm down for cat only. Screw the resonator. That's what a muffler is for.
#45 |
1NZ-FE
does it fit the seddan?
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
#46 |
#47 |
rarer than JDM -1 of 1!
I think i just realized that i am the only sedan owner on this list. What problems do i run into richard? I would love to just bolt to a axleback and call it a day.
#48 |
JDM Fred
any idea on a month when it will be done?... jw
1990 Mazda Miata... I miss my Yaris
#49 |
same with manifold
#50 |
Slowy getting there
If I screw in the O2 anti-fouler will this header pass emissions test? I live in Texas and They will use my OBD2 port to check for emissions. So aslong as the header doesn't throw a CEL I will buy it later on.
#51 |
The header itself will not throw a CEL-but the second oxygen sensor is an issue. If it can be fooled with anti-fouler then there should be no problem. If the header is run with a cat-then it will likely pass a sniffer test as well but the system is offficially for off-road use only.
#52 |
#53 |
Slowy getting there
Ok because texas only uses a sniffer on 96 and older cars so as long as the O2 sensor is reading ok, the check engine light isn't on, and its not pouring out black smoke Ill be fine. Unfortunatly I will have to buy this later I'm saving all the pennies I have for the intake mani.
#54 |
any Idea when the header will be done? I need to know how long I have to save my money before I start spending it on other mods
| Official Richard Holdener who wants to buy an intake manifold list | kou | Performance Modifications | 385 | 03-27-2009 11:29 AM |
| Long Tube Header Dyno results & Photo | richardholdener | Performance Modifications | 59 | 11-26-2008 05:27 PM |
| Long Tube Header | kou | Performance Modifications | 2 | 11-18-2008 01:15 AM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
