#1 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
#2 | |
Bacon!
Drives: 2008 Red Yaris LB Join Date: Oct 2008
FYI The DRL module is also tied into the foglight wiring. I seem to recall a user here who had some issue with his foglights after removing the DRL module. The post may have been lost in the hack and I can't recall what the exact problem was (and I'm too lazy to look for it) but it's worth mentioning. Last edited by ToddR; 12-05-2008 at 06:16 AM. Reason: typing with mittens on does not work |
[QUOTE=ToddR;190608]Fire hazard or not, it's there if you have the All-Weather Guard package. Here in the midwest cars don't warm up in three minutes during the winter. I'm really glad I have this in my Yaris, but I wonder if the high power consumption is effecting my mileage. It looks like it draws close to 40 amps when on.=QUOTE]
Well, I am in the cold New England and we are regularly +20 deg F and have a week of -10 to -20F usually once the season. I have the optional Cold weather package with HD heater and big washer bottle and heavy fan. So How do I get this special heat t work? Where exactly do you set the HVAC controls - maybe this is answer mystery why my car dies with the heat on - electric heater its taking all the juicyness far away away from my little battery
#4 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
A/C Temperature at MAX. Blower is anything but off. Engine at idle speed or faster, AKA running! Outside air is 50F/10C or less. (Cold enough to fog the windshield.) Coolant is 150F/65C or less. (Cool light is still lit on the dashboard.) It will turn the ceramic heater on in stages at 10, 20, and 30 seconds, ramping up from 20 amps to 30 amps, then 40 amps. So it's not a sudden 'surge' of hot air, but it does warm up quickly. The effect will be most noticable if you keep the blower on LOW, not high. Set the 'vents' to the far left/dash-only, close everything but the side vent on one side, aim it at your face, set blower on low, near-instant toasty.
Nice!
I gotta try this!
#6 | |
And it's actually not a fire hazard. While it can pump out 'hot to the touch' air, it can't make enough heat to actually catch things on fire AFAIK.
| Manual Transmission...Safety Issue!!! | twocvforme | General Yaris / Vitz Discussion | 189 | 10-30-2010 11:00 PM |
| RS stock page alert question.. | marcus | Cosmetic Modifications (Exterior/Interior) | 15 | 11-21-2008 09:09 AM |
| EBAY Seller Alert for Yarisworld Members | redyaris | DIY / Maintenance / Service | 29 | 07-02-2007 09:23 PM |
| Turn signal audible alert | paultyler_82 | Performance Modifications | 7 | 10-01-2006 10:21 AM |
