Old 12-05-2008, 02:02 PM   #1
pz's yaris
Drives: 2008 Black Sand Pearl HB
I have the same problem and have asked my service guy at Toyota about it. It's a common problem they have seen...there's a tray under the dash where condensation collects when the A/C is run a lot and it can get that musty, gross smell. The only thing they do is spray Ozium into the vents (Lysol is the same thing...air neutralizer/germ killer) and say to keep the vents on the fresh air when the car is parked or a/c isn't used. Not much else they can do about it...you can pay to have the a/c service done, but, I have been making sure my vents are open now and I have noticed over time the smell has gone away. It's just going to take time...a lot of time! That is coming straight from my Toyota Service Department...hope it helps! :)
pz's yaris is offline   Reply With Quote
Old 12-07-2008, 02:30 AM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Originally Posted by slvryaris View Post
I was experiencing this before when I ran the AC and then let it sit. The moisture builds up in there and becomes stale. I used the recycle air when running the heater and noticed a funky smell also. Try running the heater and AC using the fresh air option instead of the recycle.
You know what, the smell has been starting to fade away very slowly on its own since I cut down on my A/C use. Guess these colder Winter months are helping. I'll try these tips anyway when the weather starts warming up again to gauge how well they work. Thanks for the advice, guys
Old 02-03-2009, 10:44 AM   #3
mmxcix
Drives: 2008 Yaris
...It's a common problem they have seen...there's a tray under the dash where condensation collects when the A/C is run a lot and it can get that musty, gross smell...
That sucks... where exactly is the tray... anyway, i still smell it from time to time... it's not bad this time of year since I have not been using the AC due to a cooler weather... i have tried using the ozium, but that thing smells like bathroom deodorant...
mmxcix is offline   Reply With Quote
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 06:37 PM
