![]() ![]() Drives: 2009 Yaris Sedan (Black) Join Date: Nov 2008
kit to install power locks?
hey guys, quick quetsion. i got a 2009 yaris sedan without the power package, so theres no power locks installed. however, i am interested in installing these eventually and did a search and found a kit on a1electric:
http://www.a1electric.com/Merchant2/...duct_Code=W02C can anyone confirm that this is the right kit to use for my car? its a sedan so its 4 doors, and this kit is for the cable actuated locks, not the rod actuated ones. does this look like it will work? and any idea how much itd cost to have it installed somewhere? thanks! |
SIPNDEW
you can use that once since our car has cable controlled locks. if you do let me know how the install goes.
#3 | |
I sprang for the power package, worth every cent!
You get a power lock on the hatch too which is nice. Also, there's a feature that won't let the doors lock if you leave the key in the ignition. It's all covered under factory warrenty too......
#5 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
The a1 system looks pretty easy to install, too. |
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Oct 2008
do they make one for the LB????
Visualize whirled peas. Peace, Love and Good Smoke! --Tommy Chong
yes, the same kit, just with 2 less motors.
yea, heres a few links to the right ones:
this one is just like the one i suggested but for 2 doors only: http://www.a1electric.com/Merchant2/...duct_Code=W01C this one is the same but with keyless entry: http://www.a1electric.com/Merchant2/...ode=W01C-RF104 and this one has keyless entry and security alarm: http://www.a1electric.com/Merchant2/...ode=W01C-B6000 peace! |
#9 | |
Glad I got the factory sysytem.
#10 | |
![]() The $1290 for the power package adds up to very little to your monthly payments when spread over a 60mo. loan. I WOULD like to add keyless to my car though......
#11 | |
a1 also sells the part you need for the hatch. Here is the link: http://www.a1electric.com/Merchant2/...Category_Code= |
#12 | |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
i wanna install power locks....but where would you put the switch('s)?
hey pitt yaris, i believe you woul dhave to buy a new plastic molding for your door (im not sur ewhat its relaly called) that will have the bay open for your power lock switch. otherwise, you would have to home make something by cutting out a hole in your existing molding i guess. what i plan on doing is just having it so when you lock the door switch on the driver side door, all the locks lock together, and vice versa when you unlock.
i have a 2008.....it has the 2 vacant bays. was just looking at factory ones and saw theirs is on the door. i know the one under the left cup holder is for power mirrors.
ohh ok thanks. and yes i believe the power lock switches and also the power window switches are located on the door, so you would need to get a completely new part for your door that has those additional bays.
are the 2 vacant bays you are talking about, the ones right underneath the e-brake? i have 2 vacant bays there so im guessing you do too. do you know if one of those are typically used for a fog light switch? what could the other one be used for? |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 03:59 AM |
| Possible to only install the power mirrors? | WolfWings | DIY / Maintenance / Service | 0 | 09-26-2007 12:04 AM |
| Question about Yaris power locks. | OtownYaris | General Yaris / Vitz Discussion | 3 | 05-14-2007 10:48 PM |
| power locks and alarm install | acrbill | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 12-01-2006 01:17 AM |
