Old 12-09-2008, 12:51 AM   #1
gid
Drives: '08 Yaris sedan , '08 Liftback
plus the comfort of knowing it's synthetic . SECURITY BLANKET for you and your YARIS (es) . Sleep well baby YARIS .
gid is offline   Reply With Quote
Old 12-10-2008, 12:49 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
I just made the switch on Sis car to MOTUL 8100 SYN ACEA A5/B5 (their cheapest stuff) and the car runs noticably better than the M5000 I was breaking it in on. Smoother more stable idle and no noticable performance loss during warmup of the oil ( 15deg F to 195+). Car is less buzzy on the interstate at 60-70mph and the apparent midrange torque is improved (you call "butt dyno"). Cant prove it but like it. This is PAO base so not as good as MOTUL 8100 E-Tech or 300V. PAO syn is Good for winter, polyol esters for (or DI-A ester) for race or hard summer use..
_
_
#1 benefit - of REAL syn? Near zero (-0-) varnish behind piston and in chain tensioner area
Biggest zone for performance issues on modern tight tolerance engines.
Second benefit is more shear stability around the piston - so less gum higher balanced compression, less chance of stuck ring and consistent piston-will lubrication day in and out. Tear a few hundred motors down in your carreer and you will see what I mean ....
Little means HARD WORKING: Any high-specific output engine needs TLC ( yaris makes over 1-HP per Cu/In so it is POWERFUL for a1-Atmospheric engine If it was sized up to a 6.2L Chevy V8 it would be like 450HP!!
- Sonjas Bro
MOTUL is famous for their Lemans 20 -60 Race oil ( and NO dont put it in your yaris) I don not work for them
TheSilkySmooth is offline   Reply With Quote
Old 12-15-2008, 04:19 PM   #3
1stToyota
1stToyota's Avatar
Don't know much about Motul, but the Amsoil HP also has the ACEA A5/B5 rating, without the API approval. I don't want to hear any excuses from the service department, when and if I ever have any warranty issues, so I'm thinking about switching out the Amsoil HP and going with LubroMoly 5w-30, next oil change (ACEA A3/B4/C3, I think...and API certified) Maybe not as good as Amsoil HP, but better than Amsoil XL, plus I'm already using their product in my transaxle. What I like about LubroMoly is that I can get it with next day free shipping.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 11:32 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Detailed dealer pricing on the new, 2007 Toyota Yaris. tomjasz New YARIS Purchase Forum 3 08-11-2006 10:46 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
