Old 12-09-2008, 10:35 PM   #8
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I agree that Silverstars are not going to give you an HID experience, nor are they drastically brighter than OEMs, but I haven't seen any aftermarket bulbs that are truly brighter; just different light colors. If you were to significantly crank-up the wattage of the bulbs, you'd generate more heat, which could be a problem in plastic housings. That being said, I agree that the color is more pleasing and crisper, and I've had some 6000K aftermarket (ebay) H4's in my Jeep for 4 years now that I REALLY like, and I don't get flashed ever, even when I forget that my hi-beams are on. :)
Also, you shouldn't be getting bloody knuckles when you change them, so long as you take your time.
Sylvania SilverStar or SilverStar ULTRA Benggolf2 Cosmetic Modifications (Exterior/Interior) 9 11-13-2008 06:33 AM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 02:35 PM
How to remove headlight bulb with chubby hand? D: jmew0ng DIY / Maintenance / Service 2 02-22-2007 12:40 PM
OEM Toyota HID Headlight Assembly - Where to SOURCE? bigsky2 Cosmetic Modifications (Exterior/Interior) 18 12-21-2006 06:01 PM
