Old 12-12-2008, 01:00 AM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by thepoche View Post
After 4 track days, only thing that went wrong is brake pedal travel. Even after installing stainless brake lines and good brake fluid, the travel on the pedal is way more than stock.
Sounds like you have an air bubble somewhere.
You need to bleed your brakes, and maybe the master cylinder. If you have ABS and you got an air bubble down in the ABS module you will probably have to take it to the dealer.
Old 12-12-2008, 01:22 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
get brake fluid that boils at a higher temperature as well.
70,000 miles, more autocrosses than i can remember, coming up on 5 years..
what's been replaced:
front brake pads
stock clutch (at 10,000 miles.. it wasn't worn out, burned, scored or anything.. it was just too weak.. the Spec stg3 has the other 60,000miles on it)
one wheel stud (rear of the car, installer error)
more sets of Hoosiers than i want to think about it
what needs to be replaced:
swaybar endlinks
steering tierod endlinks (when the car is on R comps, you feel a very slight pop when you wiggle the wheel left/right)
brake pads again (i have Project mU pads now.. i'm gonna go back to OEM toyotas)
what has broken:
an engine
a transmission
4 sets of shift cables
3 bumpers
1 set of racing harnesses (they were out of spec)
i know this is all xA info, just thought i'd show you guys what you'll be looking at in your future of autocross/trackdays
Broken windshield mikeukrainetz General Yaris / Vitz Discussion 17 07-19-2007 07:04 AM
Horn broken, watch for finger RogueYaris General Yaris / Vitz Discussion 11 06-26-2007 10:16 PM
o nos, my imac is broken :'( Blenjar Off-topic / Other Cars / Everything else Discussions 3 06-17-2007 06:21 PM
Broken hatch window Bayou Blue Canada 4 01-26-2007 11:01 AM
yaris got broken in! bulldogs2k General Yaris / Vitz Discussion 15 10-02-2006 12:43 AM
