Old 12-15-2008, 06:05 AM   #1
lilman717
Lil Monsta
lilman717's Avatar
Drives: Super White Yaris 08 Sedan
Originally Posted by SilverGlow View Post
90% short trips mean your oil is probably experiencing fuel dilution. In addition, your oil probably does not warm up enough to boil off the fuel, and in addition, the oils is not hot enough to give the best protection; in other words, the oil may not be reaching the optimal operational temperature to maximize circulation up and around all the engine parts. This is where a lighter weight oil provides more protection over a heavier oil. And it is well known that 90% of the wear and tear inside an engine happens during the first 5 minutes of operation, and it is during this time you most want the oil to protect. It full operational temperatures (usually around 200F to 212F) there is little added protection when synthetic is used over mineral oil.
So to mitigate this I would strongly suggest running 5W-20 weight oil, as it will circulate all over the engine internals faster then 30w during the first 5-10 minutes after first start of the day, and better faster circulation during the first start of the day means less wear on the internal parts. I would use synthetic too, as it often contains better additives that will help deal with oil that is fuel diluted.
One last thought: Never equate oil temperature with water temperature. There is no linear correlation, so even if your water is 181F, your oil is not necessarily up to it's expected operational temperature, and often oil takes 20-30 minutes to reach 212F or thereabouts. And it is only after it reaches those temps, will the fuel in the oil boil/burn away.
You might want to get your Yaris on the freeway for 30 minutes at least once a week to minimize the fuel dilution issues.
So in summary:
Use the cheapest synthetic on sale that is 5w-20 or 0w-20. Another benefit of doing this is that you should be able to run your oil 25% to 50% longer over mineral before you have to change the oil.
Until the car is fully warmed up, don't jump on the gas pedel....keep it slow and smooth. You do this, and your engine wil easily reach 300,000 miles without buring oil, or losing much power.
well since it's winter, i think it won't make a different with a 5-20 or 5-30 right now because the 5 is the winter weight correct?
lilman717 is offline   Reply With Quote
Old 12-15-2008, 08:24 AM   #2
1stToyota
1stToyota's Avatar
Correct. And I don't know why he suggested 0w-20 in his reply...that's very bad advice. The Toyota TSB that he's referred to many times clearly states that 0w-20 is not recommended for the Yaris 1NZ-FE motor.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-16-2008, 01:50 PM   #3
SilverGlow
Drives: 2007 Yaris Hatchback
You are consistantly wrong. Again.
The TSB IN FACT says we can use 20 weight oil in our Yarii, 2007 and going forward. The special note at the top are for vehicles NOT COVERED by that TSB, and for those, one should look at their owner's manual, and/or what is printed on the filler cap for the proper oil weight.
SilverGlow is offline   Reply With Quote
Old 12-17-2008, 06:02 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
That lower number (0w-20 or 5w-20) is only relevant on startup,once the engine warms up the higher number is the relevant oil viscosity
Old 12-17-2008, 09:02 AM   #5
1stToyota
1stToyota's Avatar
Yes, 5w-20, not 0w-20, WrongGlow. Check the 0w-20 section. See the Yaris listed there? Of course you don't.
And I never found the part about vehicles "NOT COVERED" ...I think it states "each vehicle" after stating: ILSAC GF–4 can be used in all Toyota and Scion engines.
It's dealing with all Toyota and Scions, not Hondas and Hyundais
2008 Scion xD
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 02:23 PM
