Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 12-15-2008, 11:52 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
very nice numbers.. this proves that the new dual VVTi is severely under-rated from the factory (stock numbers) or your dyno is not properly calibrated.. i hope it's the first and not the second..
Old 12-15-2008, 12:43 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Well he is comparing against base line runs done on the same dyno. So you can look at it as a % gain.
Stock car 119whp
+ custom CAI 123 whp
+ LT header + Int Mani + Mid pipe 148 whp
We are talking about a 24% increase.
I hope that in a few years we will be able to swap heads with the new 2ZR-FAE (Same engine but with valvematic)
This engine puts 15 additional hp over our version with no Lift.
I see this as the future swap engine of choice for the US Yaris as the work to be done should be minimal.
Not to forget the new 6speed MT (C67 tranny) that it's been offered for the 2009 1.8L and 1.33L Yaris
I can see the light at the end of the tunnel....
Old 12-15-2008, 02:04 PM   #3
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
This is a great HP gain.
I drive with the stock 1.8 engine and I have already problems, on bad and wet roads, to get the power on the street. Often I have a intervention of the tractioncontrol.
How will that be with all that power?
andries is offline   Reply With Quote
Old 12-15-2008, 02:26 PM   #4
CASTREX
CASTREX's Avatar
Well as you can see from the graphs... most of the power is coming after 4,000rpm.
I don't see why would you be driving at more that 4,000rpm on a slippery / wet road.
That is of course if you are not me...
We have 8-9 months of rain a year over here... and I just loved to push the car under the rain...
If you do it safely driving on such conditions can teach you a lot about the dynamics of your car.
Old 12-15-2008, 03:03 PM   #5
andries
aka Jack Wolfskin
Drives: Yaris
Oke. I had not looked by witch revs the power was released.
(I now the dynamics of the Yaris very well)
Old 12-15-2008, 03:10 PM   #6
CASTREX
CASTREX's Avatar
Sometimes I even disengage the Trac Control / VSC and the ABS from my car.
that is some funny stuff! Is hard to learn how to control the car with all the electronic gadgets.
But for every day driving conditions, Trac Control / VSC / ABS are the best of the best!!! Safety wise Toyota did a great job on this little car.
Old 12-16-2008, 11:15 AM   #7
andries
aka Jack Wolfskin
Drives: Yaris
You can switch off the TRC and VCS without remove the fuse. The ABS is then still working.
It's a trick I've learnt from Yaris Palme, a gadget stock built in by Toyota.
Intake and Long Tube Header Update richardholdener Performance Modifications 48 03-02-2009 01:44 AM
Official Richard Holdener who wants to buy an Long Tube Header list bdc87 Performance Modifications 65 01-13-2009 04:01 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
