Old 12-15-2008, 10:38 PM   #1
Originally Posted by IsLNdbOi View Post
Where did you get the service manual? I asked above in the first post.
Also, does anyone know what the code stands for?
ALO:
ARO:
AGND:
ASGN:
AUXO:
I'm guessing "ALO" is for the left channel and "ARO" is for the right channel.
In the '07 / '08 LBs, ASGN was for ground so it's probably the same for the '09. I think "AUXO" is for the HU to sense when something is connected to the aux jack. Now what's "AGND" for?
I subscribed to TIS to have access to the service manual.
ALO: Aux Left Output
ARO: Aux Right Output
AGND: Aux Ground
ASGN: Aux Signal Ground
AUXO: Aux Output (switched input to HU to indicate that cable is plugged into Aux jack)
AGND is the shield, where as ASGND is the audio signal ground. I think they added the shield to the 09's to fix the noise issue that some people complained of in prior years.
Old 12-17-2008, 08:23 AM   #2
IsLNdbOi
IsLNdbOi's Avatar
AGND: Aux Ground
Mind uploading the '09 5-door LB's service manual here?
I looked at the connector on the back of the stock HU that the stock aux jack's harness connects to and the pins on the connector on the back of the stock HU look like needles. I thought that they were flat metal pins. If I solder each wire from my 3.5mm cable to a needle and insert the needle into the corresponding slot in the aux jack's harness connector, do you think that would work?
Old 12-17-2008, 08:32 AM   #3
With audio you really want solid connections. I would just strip a small section off of the wire going to the oem connector, wrap the 3.5mm cable's wire around it, solder and tape.
I am going to do this myself to add an Aux-Aux jack inside the driver's glove box. I might build an audio mixer to let me feed my GPS and iPhone simultaneously.
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Is MP3 AUX Jack Grounded properly? iseraph7 In Car Entertainment + Electronics (audio / video / alarm) 17 07-16-2009 05:51 PM
Aftermarket AUX jack Carvin'07 In Car Entertainment + Electronics (audio / video / alarm) 0 06-07-2007 11:52 AM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 09:41 PM
aux jack SurfBabe900 New YARIS Purchase Forum 12 06-04-2007 02:06 PM
