Tokico and KYB both are the manufacturers of the TRD Sportivo shocks. My TRD's are made by KYB. They are good, but non-adjustable. I got some Tokico "Blues" for my dad's Camry, and the ride got mildly stiffer (again, Tokico Blues are probably the same ones as the TRD's).
#2 | |
![]() Drives: YARIS Join Date: Dec 2008
Do you which model is same spac as TRD shocks (for yaris). Thank you. |
#3 | |
On that note, I had GR-2's on my GTI with some Megan lowering springs. It was a pretty smooth ride. Not as stiff as my Yaris' ride (probably due to the S.Techs). |
#4 | |
Thank you Well, your tanabe shocks is adjustable shocks, isn't it? and is it "Tanabe Sustec Pro" right? |
#5 | |
Here is my car.
more
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
If you want a ride similar to stock damping go with GR-2. The TRD shocks will rattle your fillings loose in comparison. Much firmer with resultant incredable handling when teamed with TRD springs and swaybar.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#9 | |
Thank for reply Well, blacksandiegovitz said that GR-2 will blow out if I put it with lower spring. GR-2 can use with lower spring? Thank you |
#10 | |
| Fire Extinguisher Recommendation? | stran | General Yaris / Vitz Discussion | 7 | 12-10-2008 10:12 PM |
| Tire Recommendation? | ic210 | New YARIS Purchase Forum | 8 | 11-04-2006 09:32 PM |
