#19 |
#20 |
Just call me Ray, better?
as soon as i go back 2 my old school(mid-florida tech) and tell you the book name... and yes it was legit book
#21 |
TRIM HUNTER
i agree with everything EXCEPT the wastes faster part. my tanks seem to last longer with the premium fuel but i think its just me being a BOY RACER........
#22 | |
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#23 |
well the reason i say it wastes faster is because it burns easier allowing the engine to be at ease and instead of work 2wice as hard
#24 | |
TRIM HUNTER
#25 |
at less than $20 a tank full reg or pre who cares what you put in.
#26 |
The Martian
True Dat
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
#27 |
high octane = hotter burn because it's a slower burn..
not recommended without a significant timing advance (which your stock ECU is not gonna do).. if you put premium in a generator or lawn mower you'll notice the exhaust glowing red.. it's WAY TOO HOT.. |
#28 |
like i said if and when i go to my old school ill pick up a book and post the article on premium gas...
#29 |
Higher octane has NOTHING to do with flame speeds within the combustion chamber or combustion temps. Octane ONLY pertains to a fuel's ability to resist preignition and/or detonation. Premium fuel will not harm your engine.
#30 |
if your engine does not know to advance timing (taking advantage of the higher octane's resistance to detonation) then how will you be fully burning the fuel in the given amount of time of each power stroke?
#31 |
The Octane rating of the fuel has nothing to do with flame front speeds....in other words regular and premium fuels take the same amount of time to burn.
As far as our car's ability to "sense" the type of fuel in order to advance timing...that's not how it works. The ECU runs the most advanced timing it can, and retards when detonation is detected. The manual says the car can run on regular, not that it was designed to run on regular. Barring any information as to the specifics from Toyota about how aggressive the timing was programmed to get, and taking into account the fact that the 1NZ runs a pretty high compression ratio of 10.5:1, I would posit that the ECU has the capability to retard timing to run on regular, rather than no ability to take advantage of premium. I would also through out the idea that running regular gas in hot/dry climates may be running the ECU pretty close to it's limit of compensation. I say this because LtNoogie basically couldn't run his new supercharger in pretty cool/wet conditions under any kind of load without getting detonation on regular gas. The Blitz kit is only putting out around a half a bar of pressure, which, if the ECU was programmed specifically for regular gas, should not max out the ECU's ability to adjust the timing to that extent. If he was able to run O.K. on regular (detonation only under extreme load/high ambient temps.), then I would be a little more receptive to the idea that the car was designed to run specifically on regular. The bottom line for me is this: Will the car run fine on regular? Yes it will. Will the engine be producing its maximum performance on regular? No. Detonation will cause the ECU to retard timing, thus keeping the engine from seeing the most advanced timing that it can. If anyone has any hard data from Toyota concerning the ignition and anti-knock programming for the ECU I would really appreciate it. Also, if anyone with a scangauge running regular could post some data about their ignition timing vs. load and intake temp that would be really cool. I’ve posted my data here: http://www.yarisworld.com/forums/sho...2&postcount=14 |
#32 |
![]() ![]() Drives: Toyota Yaris Join Date: Jul 2007
there is no point of putting premium on the yaris. its not a sporty engine. by all mean, if it makes the engine warm up quicker go for it.... A Current Affair or Drive did a test with E10,Unleade & Premium. E10 is came last in mileage, follow by unleaded & winner is Premium. anyway....
#33 | |
TRIM HUNTER
#34 |
Keep reading http://www.baileycar.com/gasoline_html.html
Bit long but the jist is= Our tests confirm that for most cars there is no compelling reason to buy more expensive fuel than the factory recommends, as any performance gain realized will surely be far less than the percentage hike in price. |
#35 | |
TRIM HUNTER
#36 |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Reluctant upshift to 3rd while cold (auto trans) | pauljk | General Yaris / Vitz Discussion | 40 | 01-22-2011 06:04 AM |
