Old 12-16-2008, 03:03 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You could have those plates welded to the chassis.
Then paint the plates and bar... and it would look good.
Just a thought.
Old 12-16-2008, 04:43 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Just a thought.
I think his end plates are aluminum, they wouldn't weld well. But, yeah... that IS a good solution. Weld or bolt a steel bracket to the CHASSIS, not the shock. Then you've got something solid to mount a brace to.
And I don't want to come off like I'm bashing anyone. I think it's great when people try to come up with cheap and effective solutions. It CAN be done. But, in this case, the cheap solution is a copy of what was a poor design to begin with.
Old 12-16-2008, 05:00 PM   #3
TKO
Drives: 4 door hatch
You should have spent alittle more...Here is my rear brace that I made up.
Plus, I have a matching front strut brace as well...all for $50.00
But none-the-less...Great job on Doing it yourself!!!!
TKO is offline   Reply With Quote
Old 12-16-2008, 05:50 PM   #4
CASTREX
CASTREX's Avatar
^^^ Those bars look great!!
I like how you can still maintain the rear cargo space.
Are those solid mounting points on the back?
I just had a vision... Since I roll with out back seats... I could use a bar like that one and then add some kind of a net from the bar to the floor. So I don't have all my stuff running around the back..
Old 12-16-2008, 05:57 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great looking bars, TKO!
Do you think that a similar design could be accomplished for the Yaris? That way the rear area's functionality would be retained.
I'd even go the extra mile and weld some extra hooks in there just for hanging bags and such...
Old 12-16-2008, 07:19 PM   #6
TKO
Sure...I used the mounting points for the slide out cargo cover. The weakest point at this moment is the spacers I had to fab cause, I need to bring the pocket that the cover sits in out flush. I'm still messing around with a few different options on filling that pocket.
This is the pocket I'm talking about...Yaris has one right?
Same but with the spacer in it...
Old 12-16-2008, 09:14 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The Yaris only has the rear bolt exposed. The one right behind the rear seat is covered up by plastic paneling, but I'm pretty sure the bolt is pretty much in the same area as yours.
I'm getting really interested in this mod all of a sudden. Is there any chance that you'd like to fab a few of these for fellow YW members?
Old 12-16-2008, 11:05 PM   #8
Originally Posted by Loren View Post
Brilliant, except that you're bolting to the top of the shock, and the shock is still mounted in rubber at both ends. A "brace" with 1/4" or more of flex at it's mounting points isn't much of a brace, is it?
Originally Posted by largeorangefont View Post
/thread.
The both of you always tend to do this. I know you are not "intentionally" trying to flame but the end result is, you are. Throw a tension gauge on and I'm sure that the flex is much less with, than without.
Great job on the brace kou
Old 12-16-2008, 09:24 PM   #9
pinoypizzaboy
Drives: 08 toyota yaris LB
thats nice
pinoypizzaboy is offline   Reply With Quote
Old 12-16-2008, 10:34 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by pinoypizzaboy View Post
thats nice
What the heck. how did you make those. Come make some for me =).
Old 12-16-2008, 10:51 PM   #11
TKO
I got the steel from a metal supply store. Think of it as a home depot...but all they carry is metal. And to bend them I used a harbor freight tubing bender.
I could make them...But I don't have a yaris to use to fab it up. But, most likely, I have one before summer next year.
Old 12-17-2008, 01:40 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
Toyota already gave us sedan owners a rear strut tower brace. It's call a rear window deck and has features like speakers holders, rear seat back latches, rear glass, etc, already integrated.
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 04:07 PM
