Metsu
Drives: NCP91 ; E36 Join Date: Oct 2008
Frozen/Laggy Clutch
Well in Calgary it's getting cold. Like -27 degrees C cold. It's nowhere near what I would consider the coldest for the year, which is what has me worried. The clutch pedal has become heavy and upon release, it lingers behind. Right now it isn't terrible but if it get's colder and it get's worst, I fear the clutch just siezing up.
Any of you guys experiencing winter have this problem? maybe if this is normal I can just adjust to it. But if I have like the wrong level of fluid and it is prone to freeze the line, I'm gonna want to do something before it gets colder. Thanks
I didn't know cars even worked in -27 degrees.
hrm, its never been that cold here that i know of though so far i haven't had any problems like that. Definately check with the dealer or call toyota canada and ask, no sence driving with it like that if you don't know if its could cause damage. Good luck, hope it just needs different lubrication or something. LOL at -27 degrees i'm not sure i would be fast enough to notice anything lag.
![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
at -16.6 degrees fahrenheit I'd imagine you'd start noticing unusual things about the car
I LOVE my Yaris!
Drives: 2007 Polar White LB Join Date: Oct 2008
That's C not F...
We had a spell of some below weather last winter and I did notice a little lag, but I think it just requires a bit more warm up time. I was happy the car never failed to start, no matter what the temp. THAT rocked.
We don't see things as THEY are...we see them as WE are. Lisa aka SIPNGAS |
its the liquid in the hydrolic clutch being cold....should go away once you reach operating temps
i imagine the shifter/transmission is a bit stiffer too....transmission fluid is cold cold i got that on my yaris last winter when it was below -20 and i got that on my XRS the year before that id let the car run for 5min or so and pump the clutch a few times in neutral to get the fluids moving around... but it IS normal when its that cold
Metsu
Good to hear it's normal. I'll start putting my auto start to use, but so far, even when the engine is fully warmed, my clutch stayed the same. As long as our lines are strong enough, I really don't mind and can just adjust my driving style.
I think shifting may have gotten stiffer too, but I have a ssk installed so it's always pretty tough lol. I know the brake pedal stiffened. But I like that feel haha. I think once a warm period hits I'll get the brake fluid changed to a cold weather one.
#8 | |
the first year i had my matrix i went up to northern ontario for new years (near timmins), it was -29C the day i left and the car wouldnt even turn over in the morning because the oil was so thick. now that i live out east, i made sure i had a block heater thrown in w/ my yaris purchase (among other things ;) )
Metsu
Yea...I just walked over to futureshop just to look at some things and it's like a 8 minute walk and my face like died. I think I better pack an extension cord to work with me.
#10 | |
i wouldnt be workin the clutch ALL the time while the car is warming up either....your left leg would get HUGE, lol
With the old beetle you could drill a hole in the transmission near the release bearing. Then you could spray the bearing and input shaft of the transmission with lubricant.
Audio Junky
dude.. he's talking Celsius.. thats not that cold. 0C = 32F.
I know my yaris ran fine down to 0F temps last year. I don't remember then thinking the clutch felt or sounded wierd in the cold. BUT! I have noticed it this year, and It seems when its less than 40F outside the clutch and gears in the car are a bit chunky... The best I can describe it is like rolling an octagon shaped wheel. It only feels like that for a minute however. Once i've made about 3 or 4 shifts, it seems to warm up and be fine. I no longer live in a cold area tho.. so today being in the mid 20's (F) is probably about as cold as I will see this winter. |
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
Fluid gets thicker hence a stiffer clutch. Happens to my MS3, too. Last winter was -40 one of the times I started my car up visiting my fiance in north-eastern Quebec. Redline synthetic transmission fluid gets VERY thick. Had to let the car idle 15 minutes before I could even get it into gear.
| 07 clutch burning? driver or design? | kennywhy | DIY / Maintenance / Service | 22 | 10-01-2009 01:03 AM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| Street/Race Clutch | dngz | Performance Modifications | 10 | 06-23-2007 12:05 PM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
