Old 12-16-2008, 07:44 PM   #1
kou
Drives: 08 lb
Originally Posted by Loren View Post
Brilliant, except that you're bolting to the top of the shock, and the shock is still mounted in rubber at both ends. A "brace" with 1/4" or more of flex at it's mounting points isn't much of a brace, is it?
if you take that rubber bushing out then you will see that there is metal inside which extends out the bottom that keeps it in position in the chassis.so side to side it is pretty stiff, the rubber mainly absorbs up and down movement for ride qaulity. an extra brace on the body would not hurt though.
Old 12-16-2008, 08:45 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You are forgeting 2 important points.
1 The shock is still mounted in rubber at the bottom
2 A shock by definition is NOT a LOAD BEARING member of the suspension. Bracing it, even if solidly mounted does NOTHING.
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 04:07 PM
