Old 12-16-2008, 09:44 PM   #1
daikin22
Drives: YARIS
Tokico and KYB both are the manufacturers of the TRD Sportivo shocks. My TRD's are made by KYB. They are good, but non-adjustable. I got some Tokico "Blues" for my dad's Camry, and the ride got mildly stiffer (again, Tokico Blues are probably the same ones as the TRD's).
Thank for Reply
Do you which model is same spac as TRD shocks (for yaris).
Thank you.
daikin22 is offline   Reply With Quote
Old 12-16-2008, 11:22 PM   #2
Originally Posted by daikin22 View Post
Thank for Reply
Thank you.
Sorry, I actually do not know which KYB model has the same specs as the TRD's. But I would assume the GR-2's.
On that note, I had GR-2's on my GTI with some Megan lowering springs. It was a pretty smooth ride. Not as stiff as my Yaris' ride (probably due to the S.Techs).
Old 12-17-2008, 04:17 AM   #3
daikin22
Drives: YARIS
I just saw from another your post. Are you using Tein spring w/ Tanabe shocks, aren't you? Well, I would like to ask you about Tanabe shocks which is good or not.
Thank you
Well, your tanabe shocks is adjustable shocks, isn't it? and is it "Tanabe Sustec Pro" right?
Old 12-17-2008, 04:29 AM   #4
Thank you
I believe you misread that. I have the Tein S.Tech springs with the TRD Sportivo shocks with a Tanabe Sustec strut bar. I like this set up a lot. Steering is more responsive, and body roll is pretty much reduced. However, since I do not have a rear sway bar, and if I push it hard onto an onramp, I can feel the car understeer. Therefore, I would recommend going with a rear sway bar first before a front strut bar.
Old 12-19-2008, 08:25 AM   #5
daikin22
Drives: YARIS
Here is my car.
Old 12-19-2008, 08:31 AM   #6
daikin22
Drives: YARIS
more
Old 12-19-2008, 10:26 AM   #7
MUSKOKA800
MUSKOKA800's Avatar
KYB GR-2 shocks will have the same body as TRD's however the "valving spec" will differ as the GR-2's are an OEM replacement (smooth ride) while the TRD version have much firmer valve spec's and provide a performance ride.
If you want a ride similar to stock damping go with GR-2. The TRD shocks will rattle your fillings loose in comparison. Much firmer with resultant incredable handling when teamed with TRD springs and swaybar.
Old 12-19-2008, 12:15 PM   #8
daikin22
Drives: YARIS
Thank for reply
Well, blacksandiegovitz said that GR-2 will blow out if I put it with lower spring. GR-2 can use with lower spring?
Thank you
Old 12-21-2008, 03:35 AM   #9
They don't feel that much more dampened (enough to rattle things off of the dash or anything, unlike my friend's Toaster).
Fire Extinguisher Recommendation? stran General Yaris / Vitz Discussion 7 12-10-2008 10:12 PM
Tire Recommendation? ic210 New YARIS Purchase Forum 8 11-04-2006 09:32 PM
