Old 12-16-2008, 09:44 PM   #1
daikin22
Drives: YARIS
Originally Posted by MUSKOKA800 View Post
KYB do manufacture the TRD shocks (mine at least) but the difference is the damping rates.
The TRD shocks produce excellent handling but at the sacrifice of ride comfort. If you want a "smooth" ride find a shock with much less damping than the TRD's. The KYB GR-2 shocks may be your answer. They are an OEM replacement shock with slightly greater damping than the stock units. I've enjoyed them in my previous ride (Eibach lowered Talon) and the ride comfort was maintained while still controlling the stiffer lowering springs adequately.
Good Luck!
Thank for Reply
KYB GR-2 is suitable for Yaris right?
Thank you.
daikin22 is offline   Reply With Quote
Old 12-18-2008, 01:25 AM   #2
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Originally Posted by daikin22 View Post
Thank for Reply
Thank you.
Gr-2 's are only a good "upgrade" if you blow your stock struts/shocks out . Imo stock shocks are better . If you need to go with gr-2 don't pair them up with any spring lower than like tanabe nf210's or they'll blow-out in about 2 months . Bare mininum go with a set of blue's or save a get some megan or basic tein coilovers , only about 250 more than the 500 a set of blue's/tein s tech's or tanabe springs will cost you .
Old 12-18-2008, 04:05 AM   #3
daikin22
Drives: YARIS
Thanks for reply.
Well, what about Tokiko shocks? It's can be match with lower spring, right?
Thank you
Old 12-18-2008, 10:16 AM   #4
blacksandiegovitz
Drives: 08 Vitz
Thanks for reply.
Thank you
Yeah Tokico blues are the best for the price . I 've ran blues on 3 differnt car's i've owned all with at least -2 lowerd springs and never blew a strut out . Good performance strut and pretty "firm" feeling over stock.
Old 12-18-2008, 10:37 PM   #5
daikin22
Drives: YARIS
Thank for reply
Well, Tokico will a bit/much stiffen than original shock?
Thank you
Fire Extinguisher Recommendation? stran General Yaris / Vitz Discussion 7 12-10-2008 10:12 PM
Tire Recommendation? ic210 New YARIS Purchase Forum 8 11-04-2006 09:32 PM
