remember if you use a subaru (top mount) turbo and try to mount it upside-down you'll need to turn the center cartridge to correct your oil flow path.. you should flow the oil top to bottom
i'm using the hotside from a JDM Legacy GT and the coldside from a WRX (USDM) and spool is excellent. |
#2 | |
Break'em off some.
If you mount it as Richard pictured, in the OEM airbox location, you could leave it as is. |
