#19 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
#20 |
![]() ![]() ![]() Drives: 07 Civic Si Coupe(Black Pearl) Join Date: May 2006
Well, i learned on my 91 Z28 and 97 Trans am 6-speed, that once you replace 3 transmissions, throw-out bearing including slave cylinder, 1-3.23, 1-3.43, 2-4.10 gears, pinion bearing, 2 fuel pumps, 6 sets of tires (only replaced the front tires once on each car
), 3 trans mounts and a throttle cable that when something can break you dont do your best to break it. After all that tho it was all worth it ![]() Hmm, i feel like i missed something... ![]() Maybe its just the sedan for the steering, i dunno. I'm also gonna ask a mechanic about coasting in neutral hurting the tranny. If the pump runs off the input shaft, then even in neutral the input shaft still spins w/ the engine on. Also the computer knows the trans temp, so if it does overheat the check engine light would come on. |
| Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! | TRD_Yaris | General Yaris / Vitz Discussion | 183 | 02-01-2017 12:18 PM |
| Scangauge finaly available | pennystocks | General Yaris / Vitz Discussion | 26 | 07-10-2006 07:22 PM |
