#1 | |
oem is 185-60-15 205-40-17 are within 1.23% of the oem rolling size 215-40-17 are within 0.125% really, youre only going about 1% farther rather than 7%...
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Go to this web site and submit those two sizes in, and you will see that the stock tire has a circumference of 72.09 inches (1831mm) whereas the larger tire I am running has a circumference of 77.31 inches (1963.6mm). That's a diameter difference of 6.75%. Do the math and you will see the tire travels a distance of an additional 5.22 inches per rotation over the stock tire. As the odometer is set for the stock tire, you must add the addition of 7% (rounded up) to the odometer distance traveled. Last edited by MadMax; 12-18-2008 at 08:58 AM. |
#3 | |
#4 | |
Plus, I own a Jeep, so I am very familiar with oversized wheels and tires! It is very common in the Keep community for people to put huge tires on their rigs. Besides suspension modifications, the only real requirement for larger sizes is regearing (for going from 29" tires to 35" or larger); but that is not an issue here. The stock Yaris with an AT can easily handle 17" wheels, and you can even lower it by changing out the springs to some degree without having rubbing issues. People all over this forum have done this, and there are numerous threads about it Cheers! M2 |
#5 | |
as for a source of that 3% rule...1010tires.com, the place you linked to goes red if you put in a size thats 3% larger than your stock tires on the tire size calculator...see: ![]() the tires you bought are sized for a corolla.....
| getting bigger rims = odometer/speedometer changes? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-27-2008 12:43 PM |
| 17"&18" rims and effects? | microbe__ | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-23-2008 12:09 PM |
