Old 12-17-2008, 07:58 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by msfire671 View Post
do these eyelids come off easily?
It is NOT easy to remove the eyelids, as long as you use the 3M tape that I recommend, which is designed to bond with the plastic parts of your car. Then again, if someone tries to pry them off, they may damage the eyelids, which means that at least that idiot won't be able to use them for anything.
Originally Posted by Treyz View Post
I have v2 which still have a base to them. I believe it's v3 that have that part eliminated.
The difference between v2 and v3 is essentially just the base, as Treyz correctly mentioned. The base may help a bit on this issue, but not really. The upside of not having the base is that the eyelids are much closer to an OEM look, and there's virtually no rubbing when opening/closing the hood.
So, in essence, the eyelids are as secure as any other "add-on" body part that is attached to your car (be it a spoiler, rocker panels, etc). Obviously those parts will be more secure if they are drilled/bolted in place as well as taped, which is something that cannot be accomplished with the eyelids.
The Official "Bambo the Yarisworld Traveler" thread (V1) nemesisz Off-topic / Other Cars / Everything else Discussions 3 11-08-2008 11:24 PM
I can't seem to find the thread with the pics of the '08 brochure, help? Jailbird General Yaris / Vitz Discussion 1 09-11-2007 09:40 PM
Sterio Pics Thread BlueFlash Off-topic / Other Cars / Everything else Discussions 0 06-08-2007 05:55 PM
