Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Redyaris here again with another DIY. As usual, I like to submit these to show how easy it is to work on this car.
I recently purchased a strut tower brace bar from a seller on Ebay for around $40. There's been a lot of debate on yarisworld about the effectiveness of these bars. Some swear the car feels better in corners, some don't. Whatever. For the record, I can't say that I noticed any change in handling. I like the way it looks in the engine compartment and that's all that matters to me. YW member and moderator Chris07LB did a DIY on the Tanabe strut tower brace a while back. Here is a link to his DIY http://www.yarisworld.com/forums/sho...trut+tower+bar A great writeup that perhaps I can add a little more to with my version. My cheap no-name brace bar came in unfinished aluminum with supplied bolts, nuts and mounting plates. Just like Chris07LB, I trashed the included mounting hardware for higher grade materials (longer and heavier grade 8 bolts, washers, and nylock nuts). What I didn't know from the previous DIY was in order to bolt the mounting plates to be attached to the strut towers, I would have to remove the windshield wipers, windshield trim and a metal support plate attached to the firewall. What a historic pain in the ass. First you have to remove the windshield trim pieces where the washer sprayers are mounted. Undo a couple of plastic trim clips to begin. There are two pieces you have to remove. The bigger piece on the passenger side comes out easily. The smaller piece on the driver side requires the removal of the two windshield wiper arms. Pry the wiper arm attachment nut cover off with a small screwdriver. Use a ratchet to unbolt the wiper arms. Tip: once the nut is off raise the wiper arm up from the windshield to remove it (it won't come off if laying flat). After the wiper arms have been removed, remove the trim piece. Next you will have to remove several 10MM screws holding a large black metal support piece attached to the firewall. Some of the screws are hard to access so use your 10 inch ratchet extension. I recommend you take your time and drink a lot during this process. ![]() The wiper blade assembly will have to be removed before the support piece will come out. There are 2 10MM screws that hold it in place. Slide the wiper assembly to the left and it can be removed. There is also an air intake vent on the passenger side that can be slid straight out for removal. Once the large black support is removed from the engine compartment you now have free access to the strut tower mounting points (2 on each side of the car). Using a floor jack or jack stands, jack the car up and remove one or both wheels to gain access to the wheel well strut tower mounting holes. I did one side at a time myself. Note: Before installing the bar, the car will need to be back on the ground supported by all 4 wheels. For the next part of the strut brace install if you have large hands you are screwed. I had to fish the bolts up through the wheel well through the strut tower mounting point holes. This required a lot of patience and a lot more drinking. Put the wheels back on and remove floor jack and/or jack stands. The vehicle must be back on the ground supporting itself for installation of the bar. My brace bar was adjustable for length so i test fitted it to the mounting hardware. Install the bar using two bolts one at each strut tower mounting plate. Tighten securely. I don't recommend nylock nuts for this as you will have to remove the bar when servicing the car (installing a new battery for example). There. Completed in just under 2 hours with 2 beers remaining in the fridge. ![]() I did a test drive and not too much to report there. As I said I like the looks. A cheap mod in my book. If it adds extra handling, well thats a bonus.
Bringin the Bling to Yarisworld Last edited by redyaris; 12-18-2008 at 11:40 AM. |
| For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. | TRD_Yaris | Items for Sale by private party | 6 | 05-06-2010 07:43 PM |
| 2001 Toyota Vitz RS Front Strut Brace | mistervitz | General Yaris / Vitz Discussion | 7 | 10-23-2008 01:36 PM |
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 02:56 PM |
| Strut tower bar | tmyers82 | Performance Modifications | 24 | 02-06-2007 03:03 PM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 07:53 PM |
