#12 | |
Go to this web site and submit those two sizes in, and you will see that the stock tire has a circumference of 72.09 inches (1831mm) whereas the larger tire I am running has a circumference of 77.31 inches (1963.6mm). That's a diameter difference of 6.75%. Do the math and you will see the tire travels a distance of an additional 5.22 inches per rotation over the stock tire. As the odometer is set for the stock tire, you must add the addition of 7% (rounded up) to the odometer distance traveled. Last edited by MadMax; 12-18-2008 at 08:58 AM. |
| getting bigger rims = odometer/speedometer changes? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 11-27-2008 12:43 PM |
| 17"&18" rims and effects? | microbe__ | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-23-2008 12:09 PM |
