Old 12-20-2008, 02:20 AM   #1
raz1121
Drives: 2008 Yaris Sedan
@ Spades
Since i see you have a sedan i havnt looked yet but where is the best spot to run your wires to your trunk?
raz1121 is offline   Reply With Quote
Old 12-20-2008, 10:32 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by raz1121 View Post
@ Spades
i ran my RCA wires in the middle of the car (where the handbrake is)
and my speaker wires go to the front from each side of the car.
power wires should not affect speaker wires, but will affect RCA.
Old 12-20-2008, 11:19 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Pretty much your car is a big puzzle peace, i don't think it has many screws, only place ive ran into them is behind the radio. For my sedan i ran the power down the driver side by pullin up the door sills. the rca and remote wires i ran down the passenger side same method although i put a switch on my remote so i can turn off the amp when my daughters in the car. 4 Gauge power had no problem running through the side of the carpet. On your rca's the more shielding / insulation the better, speaker wires for your components shouldn't be to much of a prob 12-14 gauge should suffice, for the subs i'd use 10 gauge if you're running a huge system like 1000's of watts from amp to subs i do remember radio shack selling some 8 gauge speaker wire they'd sell by the foot, tht's the only thing i ever bought from there. thing is if you have dual 4 ohm it gets to be a pain in the butt wiring a thicker gauge into the speaker terminals.
Ps if you have trouble getting through the firewall let me know and i'll take pics of where i ran my wire. On another note see if there's any mom and pop audio shops in your area that carry power acoustic, kole audio stuff like that it's not grade A stuff but it's better than radio shack
Old 12-20-2008, 09:44 PM   #4
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
@ Spades
i ran them underneath the side trim along the doors. no pulling up carpet that way. i just ran the wire under the dash, under the kick panel, and lifted up the plastic trim on the bottom of the door sills. out of sight, and there is enough space for a remote wire, a 4 gauge power cable, and RCA's. on the other side of the car i ran the ground wire.
