Old 12-20-2008, 12:08 PM   #1
richardholdener
Drives: 2008 Yaris hatch
Altering the IAT value to show colder inlet air temp can also increase ignition timing.
Originally Posted by Loren View Post
There is no "circuit", it's just a resistor in a fancy box. It is installed inline with the intake air temp sensor and causes the ECU to read the temperature as lower than actual. Since cooler air is more dense, this makes the ECU "see" that more air has gone into the cylinder and it injects more fuel. A slightly richer mixture can give more power under some circumstances. But, this only happens at full-throttle or during warm-up when the ECU is not in closed-loop operation. In closed loop, O2 sensor feedback will correct the error induced by the faulty temp data.
So, it "might" give you slightly more power when you get on it, but there's no way it's going to improve fuel economy.
That's all there is to it.
richardholdener is offline   Reply With Quote
Old 12-20-2008, 09:00 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Good point, Richard.
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
Performance Chip or Rip off??? MoeStylez Performance Modifications 28 10-02-2010 08:46 AM
Performance Chip njyaris General Yaris / Vitz Discussion 5 07-04-2007 12:19 PM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
Performance Chip *to funny* Imagine Off-topic / Other Cars / Everything else Discussions 11 05-04-2007 01:22 PM
