SIPNDEW
need pinout of ignition switch
i was wondering if someone could tell me what the pinout of the ignition switch is. i have looked at the connector and see it has 6 wires running to it. what is each wire?
thanks! |
there's actually 7 wires? I looked into that, they connect in weird ways at each stage (ACC-ON-START)... look at the engine control PDF on www.etimago.com/yaris/repairmanual , page ES-249
SIPNDEW
i looked at my plug last night and spot # 3 and spot where #8 would be are empty. and 7 (black wires) have 2 wires running into that same hole. how can i tell what color is what in that diagram? lol
#4 | |
Yellow - Switched +12 VDC Pink - Ignition Green - Start White - Accessory |
SIPNDEW
thanks a ton!
SIPNDEW
is there a constant 12V here or do i tap into it elseware?
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Someone really needs to upload the '09 service manual and other '09 related files here.
I will eventually. I subscribed to TIS for one day and grabbed all of the EWD's and about 90% of the rest of the 09 service manual. I just need to convert the EWD's from the .svgz format (readable to Adobe Illustrator) to PDF so all can open them and combine the 1000+ separate documents into smaller groups. I had to print each small section (2-3 pages each) to pdf from the TIS site.
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| New Foglights with Wireless PILOT switch | Rotorheader | DIY / Maintenance / Service | 3 | 08-11-2007 11:03 AM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
| Ignition switch heats up | kurokoma-kun | General Yaris / Vitz Discussion | 11 | 06-19-2007 02:53 PM |
