Old 12-23-2008, 07:26 PM   #1
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Originally Posted by b_hickman11 View Post
If you look in your owners manual it will tell you what to do in this situation. If you look down on the middle console where your gear shifter is, you should see a little square shaped piece that is right above the shifter. If you pop that little cover off and stick your key in there, it should fix your problem.
This sounds like the likely culprit - had a similar issue in a Mazda 626. Let us know what happens.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 12-24-2008, 08:34 AM   #2
1stToyota
1stToyota's Avatar
But putting the key in the console slot is to move the shifter, not the ignition lock, correct? I always thought that was for times such as needing to be towed, but couldn't get car out of park because interlock switch wouldn't work due to a dead battery, bad connection, etc...
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
