Old 12-24-2008, 10:50 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
the key tag is your key number. They use this to make a key they don't have a key to make a key.
at 10k miles, you need cabin air filter change if you have one. That's it. There's a check up at 20k miles, you might want to check your maintenance schedule.
Old 12-24-2008, 12:36 PM   #2
b_hickman11
Drives: 08 Sedan
Thats not the only thing you need at 10K. You also need to change the oil and filter, which is the whole purpose of the light in the US Yaris.
Old 12-25-2008, 09:22 AM   #3
IllusionX
i supposed that everybody would know it's OIL CHANGE time when the light is up. So i just answered what should be done beside the regular oil change.
Old 12-26-2008, 09:47 AM   #4
b_hickman11
Drives: 08 Sedan
Actually on this site there is a lot of people that would not know that.
Old 12-29-2008, 12:10 PM   #5
TheSilkySmooth
TheSilkySmooth's Avatar
Do what your maintenance manual says to do, NOT what the dealer OR anyone on any forum. BTW, get your filter at an independent auto parts store; they MAY be 1/2 the price of the dealer and its a 3 min job putting it in BUT dealer will charge you a 1/2 hr to install. So unless you're fudging helpless, do the cabin filter yourself. Most Yarii DONT come with one from the fact-whorey.
Last edited by TheSilkySmooth; 12-29-2008 at 12:11 PM. Reason: your/ you are screw up
How do I reset maintenance light? Snake DIY / Maintenance / Service 10 06-04-2010 12:57 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
