Old 12-27-2008, 05:18 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
That's reassuring, I haven't tried yet, as I was busy today helping my brother in law buld his house, however I am reasonably comfortable with wiring, car or not, I just want to make sure I do it right. The only real question that I have without actually trying yet is that: do you need to have a bypass toggle for the clutch switch, or can you just tap into the wire to the starter (well, to the ECU to send the start signal) as your "starter wire" from the unit? Or should I completely eliminate the clutch switch altogether? I dont know if having the switch permanantly "engaged" would cause any problems.
Thanks a lot
Old 12-27-2008, 06:50 PM   #2
auxmike
auxmike's Avatar
Thanks a lot
As a rule these tend to be sold as "automatic transmissions only". Bypassing the clutch switch and then leaving the car in gear ....OOPS!
BTW, Sodium Duck rocks an auto LB as do I.....
Old 12-27-2008, 08:34 PM   #3
My 09 is auto as well. There are units specifically designed for manuals or as mentioned in some other threads one can build a neutral safety switch using four springs mounted closely around the base of the shifter. The clutch switch does need to be bypassed to allow the car to start. The manual specific kits have an output that only bypasses the clutch switch in auto-start mode. To do the same with the 561r you'll need to use an auxiliary relay.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
remote start rumor... anubisx99 In Car Entertainment + Electronics (audio / video / alarm) 11 12-28-2008 10:53 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 05:06 AM
warranty issues & remote start homerj In Car Entertainment + Electronics (audio / video / alarm) 14 11-27-2008 12:19 PM
