![]() Drives: 07 Yaris sdn Join Date: Aug 2006
Add remote to factory keyless.
My 07 Yaris Sedan with factory keyless only came with one remote key (Which seems to be normal). I wasn't going to pay the $200 plus dollars for one from the dealer. I found one on ebay for under $100 (MAKE SURE THE FCC ID INSIDE MATCHES YOUR CURRENT REMOTE) . I got it cut & then programed it myself. For factory keyless remotes I used instructions for Toyota TSB EL004-01.
1- Driveres door open & unlocked. Key out of ignition 2- Insert & remove key 2 times within 5 seconds 3- Close & open drivers door twice within 40 seconds 4- Insert key into ignition & remove 5- Close & open drivers door twice within 40 seconds 6- Insert key into ignition 7- Close the door 8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK" - ONCE for ADD mode - TWICE for REWRITE mode 9- Remove the key from ignition 10- To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 8 11- Within 40 seconds of confirmation - Press both transmitter Lock & Ulock buttons simultaneously - Within 3 seconds press transmitter Lock button for more than 1 second - If successful, the power locks will cycle once (twice indicates transmitter problems) - Repeat step 11 for additional remotes 12- Open door to exit programing |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 09:57 AM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
| Should I add remote key less entry? Options | YotaYarisUSA | General Yaris / Vitz Discussion | 13 | 05-02-2006 05:06 PM |
| FS Various OEM keyless Remote | riceboy | Items for Sale by private party | 0 | 04-14-2006 02:42 PM |
