Old 12-29-2008, 09:26 AM   #1
Return of the Yarii
Drives: 2007 Sedan S
Here's my 2 cents, I have used N2O on many of my cars and bikes over the years. Chino you are aware this set up (minus the cost of the manifold) will be in excess of 1k? Sure, you can hack together a kit and a very basic set up for probably 700 or so but you really need to decide if you want to do it. I read you want this for track use, well how many times are you going to make it to the track? If you want N2O for show like the others who have it (one member sprayed 2x and thats it?) then great.....get a basic kit and have at it. Personally Im not the type to boast about having N2O and then not use it.
Now, if you want your motor to survive and be reliable then you will need a bottle warmer, purge kit, aux fuel pump, etc. which adds at least $500 to the cost of a kit and now your at 1000+ not including tuning. Also since you mention track use keep in mind your 1st couple of passess and last couple of passes on the bottle will not be consistent and if your drag racing consistency is the key.
Personally N2O is great if used correctly. Like I said I've sprayed a bone stock Eclipse to my turbo ZX1100 to my single turbo Mustang w/plenty of success. Its all about purchasing a high quality kit and the additional parts to safeguard your engine. And then there is the tuning.....
Return of the Yarii is offline   Reply With Quote
Old 12-29-2008, 12:12 PM   #2
Chupacabra
Drives: 2009 Yaris liftback
Exactly...I would not recommend "learning lessons" on a daily driver. I highly recommend doing a lot of research and speaking with a lot of "experienced" NOS guys. To do it right, learn out to use it, tune the car to use etc. is time consuming, costly and at the end of the day STILL no guarantee that you won't do damage or toast the motor.
Chupacabra is offline   Reply With Quote
Expressions and Explanations thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 11-09-2008 05:55 PM
Is there a thread about..... Letsrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-01-2008 12:25 PM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
Thread request - Yaris is new in the US makaluch Cosmetic Modifications (Exterior/Interior) 1 08-13-2006 12:16 AM
